BobRv4
So I passed the flight test the very first try! All was well until I hit the
registration hick up. Seems my RV4 under "MFG DATE" says "NONE".
RED FLAG no rebate.
So anyone know the FAA form on how to add a MFG DATE?
Or how to correct the problem?
Double check your registration to see if that block has a date and not "NONE"!
The mfg. date for amateur-built aircraft is the date of certification. That should have been on the 8130-6, application for airworthiness.
A call to registration should straighten things out.
thanks
ok, thanks will call next week. My MFR date is blank, that's causing the snag.
Just FYI I did contact the ADSB folks got an email back within an hour they extended my date till May, which I thought was nice.
A friend has a Cherokee that had the same problem. He called and sent them a copy of his Airworthiness Certificate and that fixed it.
