Mike S
Senior Curmudgeon
Here is a link to the NavWorx installation, presented as a block diagram.
http://www.navworx.com/PDFs/GRT-display-ADS-B-Traffic-block.pdf
Sorry, I cant figure out how to post the actual image
My question is the encoder input------it clearly shows the encoder going directly to the NavWorx box, and not to the transponder. Is this correct??
Should there also be an encoder feed to the transponder??
Should the encoder feed into/through the transponder to the NaxWorx unit?
If the encoder is already feeding the transponder, does the needed information back feed to the NavWorx unit over the RS 232 line??
