My plane has Garmin GTX 330 that just had the ES upgrade done by Garmin. I have a GNS430W that according to my avionics shop, now just needs a wire run from the GNS430W to the GTX330 and then I should be ADS-B out compliant. I have not had the wire installed yet.
I use a Stratus 2S and an iPad mini to receive ADS-B in. Today, I noticed several times on my iPad an ADS-B target showing 300 ft directly below me going the same velocity and direction of my flight. It spooked me a couple of times till I figured out the indication had to be coming from my own transponder.
As I said before, my transponder has not been wired to receive the input from the GPS yet, but I am positive that the ADS-B in I'm seeing on the iPad is from my own transponder.
Has anyone seen this before or know what might be going on?
Curt
Curt
