RedRaider94
Active Member
Need some advice from the group on my best solution for ADSB IN to GRT HX.
Right now my setup is:
Garmin 330es
Garmin 430W
Dual GRT HX screens
Stratus ADSB IN for ForeFlight
I get TIS traffic on the GRT and 430 screens today from the 330. I get ADSB in my iPad in foreflight.
The Stratus won?t work with GRT EFIS or my problem would be solved.
What I want is to replace the Stratus with a unit that will easily connect to the GRT and ForeFlight. USB into the GRT would be easiest but I could do a serial connection into the EFIS if needed.
I want the adsb data on both GRT screens so not sure if I need to wire to both. Also don?t know if there will be redundant data showing up from the 330es if I add adsb in.
Have been looking at FlightBox pro but would need to permanently install somewhere, add two antennas under the plane, etc. This is possible if it is the best solution but wanted to see if anyone else had a similar situation and solution or any ideas.
Shawn
Garmin 330es
Garmin 430W
Dual GRT HX screens
Shawn
