BruceMe
ADS-B SIL / SDA failure (solved)
I've installed a GPS 20A with my GTX 23ES via the Serial 2 receive pin (serial 1 was already being used by the old G3X). The GPS 20A is also the GPS source for my G3X via CAN. It appears to be operating well, but my ADS-B report is stating I have total failure of all SIL and SDA.
I believe the 20A / GTX 23ES is a valid combination, so I'm not sure why the SIL/SDA is failing. Is this just a bad software configuration on something that I can fix with dials? Before I tare into my panel again, should I move this to serial 1 on GTX 23ES? This takes about an hour.
-Bruce
-Bruce
