T texdog Well Known Member Jan 14, 2019 #1 I have a GRT SPORT SX and GRT Sport HS. No WAAS approved GPS, but a Garmin 696 is mounted in the panel. Which screen should I put ADS-B in to? Thanks
3 330drvr Active Member Jan 14, 2019 #2 Assuming you have an 232 from your ADS B IN, split it and connect to both.
Skid Well Known Member Jan 14, 2019 #3 ADS-B in Which one do you use as a primary display? Do you have any hi speed ports available in both displays? GRT Fly-Safe requires a hi speed port for the connection, not sure what other use.
Snowflake Sidney, BC, Canada Sponsor Jan 14, 2019 #4 Depends on your ADS-B in device. A Stratux will feed the GRT display, I understand, but it won't feed the Garmin.
B BobTurner Well Known Member Jan 14, 2019 #5 Also depends on your panel. IMHO weather can go almost anywhere, but traffic is best if it?s displayed right in front of you (main PFD).
