Michael Burbidge
I'm installing a Garmin GDL-82 to meet the ADS-B out requirements. I'd like to place the antenna on the outside of the aft fuselage directly in front of the vertical stabilizer. I have two questions. 1) Will the VS block GPS signal. 2) The install manual says the antenna must be level in flight. Will the angle of the top of the fuselage at that position cause problems?
Michael-
Michael-
