L lukezimmerman Member Feb 23, 2018 #1 Has anyone put their RV on scales before and after a professional/clear-coat paint job, to determine the added weight?
T tfriendshuh Well Known Member Feb 23, 2018 #2 Sherwin Williams Sky-Scapes aerospace base/clear paint. Same paint Cirrus uses on their planes. by Midwest Aircraft added 11 lbs moved CG aft by .25inches Before: After: Last edited: Feb 23, 2018
Mark Dickens Well Known Member Patron Feb 23, 2018 #3 This is consistent with what Jonathan McCormick at Evoke Aviation told me as well. About 10 lbs if the painter knows what he's doing!
RV6_flyer Well Known Member Benefactor Feb 23, 2018 #4 20-years ago, I used same set of scales to weigh RV-6 after paint that I did before 1st flight. Weight increased 8-pounds so the number of 10-pounds sounds very reasonable to me.
