A alcladrv Well Known Member Feb 4, 2021 #1 In reference to the attached document, where would I tie in a stick-mounted PTT switch? Thanks! View attachment Dual Comm without Audio Panel.pdf
bjdecker Well Known Member Ambassador Feb 4, 2021 #2 Put a momentary contact switch between the microphone tip and ground.
B BobTurner Well Known Member Feb 4, 2021 #3 It goes to the wire labeled ‘blue’ coming off the mike jack, e.g., the one that goes to the tip of the mike plug.
