What system? Dynon mounts in the wing bracket included with kit. Garmin most people mount AHRS on the back of the PFD and the magnetometer in the kit wing bracket (fits Dynon or Garmin).
I installed a the dual SkyView ADAHRS modules in the kit provided wing mount bracket on an RV-14A. No remote magnetometer required or desired. Three years of flying and all is well.
Carl
Carl
The wing mount bracket you mention that comes with the kit. Is that the Dynon ADAHRS kit or the 14A wing kit? Cuz my wing parts inventory doesn't seem to have an ADAHRS bracket.
It should be in the wing kit, it was for me. If memory serves, the wing is already drilled for it as well.
Carl
Yep, the module slides in and the retaining tab clicks in to hold it. For mounting dual modules you need the joining plate designed just for this. Really a nice, clean solution.
Carl
Carl,
I guess I need a picture. It is not obvious to me how the module slides in and is retained by the tab. Here is what I see through the service window from the leading edge looking aft. It's kinda dark. I hope you can see what I see.
