hcccs
I installed the RPCI and Audio Alert module in the panel and connected them with the little telephone cable which I had shortened and crimped on a new RJ11 connector. The RPCI started ticking and the LED started blinking immediately. I thought I had turned the connector the wrong way and I cut it off and crimped on another the other way around and it still ticks and blinks when I connect them. Is this normal? The ELT was not connected. Which cables are straight and which are cross-over?
Compare both ends of the cable. The wire colors should be in the same order in the connectors, assuming they use a standard phone line.
Some of the ACK instructions say that the old 121.5 cockpit monitor portion would be compatible with the new system.
That was not what I found and I had to use the new one supplied with the 406 unit. Of course it's dimensions were different...:mad:
Are you using an old 121.5 unit cockpit portion?
Partly solved.
No, it's all new things. I received the kit a week ago. I replaced the plug on the little cable and now it's silent so that one is OK. Is the long cable between the ELT and Audio Alert a straight-thru or crossed-over cable?
