cgrossl
Hello,
I know this isn't an RV related question, but I know that this forum has alot of Lycoming knowledge floating around, and it is very active so I thought I would ask you guys this question.
I just bought an Acrosport II that came with a disassembled O-360 A4A. The engine is almost complete, but it is missing the crank. I found a nice yellow tagged O-360 A1A crank, but I am not quite sure if it will fit or not. I read the type certificate for the O-360 and the only differences between the two engines are that the A1A is equipped for a constant speed prop (hollow crank), and the A4A is not, and the A4A has special length propeller bushings. I am going to be using a fixed pitch prop, but I may upgrade to a constant speed prop later. Can I use a plugged, A1A crank, in an A4A engine? Are the cases identical, or is the oil routed differently? I don't suppose there is a downloadable Lycoming parts manual on the internet anywhere is there?
Cameron
Cameron
