tkatc
I recently discovered a new technique used by "A" model pilots on takeoff. I was taught to keep the stick full aft while applying power then relieve some pressure as you begin the roll. Continue to hold slight back pressure and let it fly itself off the ground. The nosewheel never really loses ground contact until liftoff.
The new technique I discovered has the pilot continue full aft stick while applying power, this gets the nosewheel off the ground almost immediately and then you hold that posture until it flies off. Basically you balance a "wheelie" the entire takeoff roll.
What technique is more common? Have the nosewheel failures ever occured on takeoff or just on landing?
