After I decided not to get up at 0430 to try and make the Cedar Mills Breakfast, I was left with a decision of where to fly today when I DID get up....thought about BBQ, but then found out about a neighborhood evening BBQ here, so didn't need that....since I have a long trip coming up later this week, I really didn't need a cross-country anyways, so I decided to get a little current performance data to see how the Val is doing in cruise with almost 600 hours on the clock. At the same time, I could take a look at the area where Hurricane Humberto made landfall to see if there was much visible damage or flooding, so I launched up the coast with a step climb, taking data at each thousand feet of pressure altitude.
The premise was this - I wanted to see what kind of speeds and fuel flows i was getting the way I usually fly - not when I am going for maximum speed. That means I level off, bring the RPM's back to 2350, and lean the heck out of the thing - usually get slightly LOP, even though I am carburated. I try and maintain 75% HP until I reach an altitude where I can't, and then I am Wide Open Throttle (WOT) after that. SO don't' worry that the Val is slow - she's not - I can open things up down lower, increase the RPM to get more HP (and burn more gas) and scoot along at 175 KTAS if I want - but usually, I try to get a little more endurance than that.
Here's the data I took - you can see very clearly that the Density Altitude was about 2000' higher than pressure altitude, so the altitude at which I could maintain 75% was lower than 8,000 pressure altitude today. I usually flight plan 170 knots if I am cruising between 7,000 and 10,000, and that is about what I get. Lower than that, I can still get the speed with more HP. Higher than that, I am slower, but burn less fuel.
Pressure Density TAS Percent Fuel Flow MAP Notes
Altitude Altitude (knots) HP (gph) (inches)
3000 4400 165 75 8.5 24.2
4000 5350 166 75 8.2 24.0
5000 6600 166 75 8.0 23.8
6000 7750 166 75 7.9 23.8
7000 8900 168 73 7.7 23.2 WOT
8000 9945 170 70 7.4 22.3 WOT
9000 10925 168 67 7.2 21.4 WOT (170 KTAS @ 2550 rpm)
10000 12000 163 64 6.7 20.6 WOT (166 KTAS @ 2550 rpm)
All data taken at 2350 RPM (except as noted on last two altitudes - at those altitudes, I took the 2350 data, then increased RPM 2550 to see how that added to sped. Also increased fuel flows.)
Now here's a question to set off some discussion for the week. We all know that at lower power settings, there are multiple combinations of MAP and RPM that can be used to get a specific Percent HP. Percent HP is directly proportional to Fuel flow, so once you have decided on a HP setting, you have committed to a fuel flow. But should you use a higher or lower rpm (when you have a choice) to get that percent HP?
(Pin pulled on grenade, grenade tossed into forum with usual suspects, ducking for cover...
Paul
Oh....Hurricane Humberto didn't leave much trace from 5,000', and didn't stop the big Gator Festival in Anahuac, which was in the target zone....
Paul
