leeschaumberg
Ameri-King makes a cheap (200.00) and light ELT that covers 121.5,military, 406, and has voice transmit capabilty. The AK406. This way you could tell the folks that it hurts and they should get thier butts here now! This unit comes with antenas and mounting bracket. It uses 6 d cell batteries and has an opitinal extended warranty. After checking the ELTs out there this one looks good. This ELT has been around since the late 90s so it must work OK. Now if we could make it fool proof (antenna can't break off) we would be done. The mounting location will help solve this problem. If one is still alive after the crash it could be used as a PLB. It is water proof unless you go down to the Titanic.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
