ron sterba
Well its time for the the Plexiglass to get fitted to the frame on my 9A. I'am gathering comments on your installation. I have built the tracks to specs and the top rail and the rollers in the tubes.
After reading the plan directions and talking to the factory rep and gathering construction ideas from several builders I feel I'am ready to mount and cut the plexiglass.
So far I have heard cut this LONG.LEAVE YOURSELF SOME FOREGIVENESS. Install the side panels in metal or do them in fiberglass. OK TO USE SPACERS.SIKAFLEX or RIVETS. All of the above makes great craftsmanship as they told me their build stories.
I have come away thinking that the welders of the frames are the problem. My builder friend said how come we don't have to re-shape our engine mounts? They're welded! GOOD COMMENT I said. So this is a exericise in fruitility or what! Company sponsored education? Well I'am not all that sure. As my professional welder friend said the cool down process of a precision part should be done in a bath of oil for proper cooling of the weld.
Well I'am not a welder but but I can surely say that the builders I have talked to have dug into canopy project like that of a hike into the forest!
Alligators that look at you with a appetite just inviting you in. Keeping that Alligator going in the right direction means tapping the ground on either side of him on the straight and narrow road to perfection. Seems that builders enter that hike on all different paths with one goal in mind. THE RV SMILE!! ONLY ONE TRIP THROUGH THE FOREST!!!!! So I'am soliciting your paths either through the forest or the path with the least resistance. I hope my jungle is like yours! Builder websites invited as well as every comment. Just remember to use dashed lines in your descriptive words of WISDOM! Thanks to all whom share and to all whom learn!
9A Ron in Oregon
9A Ron in Oregon
