wings and flaps mounted on fuse. Right inboard flap gap seal sits snuggly against fuse-beautiful. Left inboard flap gap seal hangs about 1 1/4 inches below fuse belly skin. Talked to Van's-said that this sometimes happens and to just bend the left flap flange up till it kisses the belly skin or to just leave it-no adverse effect on flying. Rechecked everything multiple times before and after setting incidence on trailing edge spar, straightness of flap, etc. everything is to spec. Anyone else run across this problem and if so is there a fix other than Van's? thx, Mike H 9A
