Av8torTom
Hi all,
I'm working on the center section of my 9A fuselage. Couple of questions:
I have drilled the 1.5" diameter hole for the step in the F-725 baggage floor stiffener. The plans say to notch out the F-623 corner ribs. Should the should the part of the step that goes through the 1.5" diameter hole in F-725 be held perpendicular to F-725 while marking for the notches in F-623?
On page 8-6 it says - Rivets at the intersection of the spanwise row across the forward F-904 bulkhead... a smooth inside surface will help fit the stiffeners properly.
Can someone help me understand that that paragraph is saying???
Sorry for being so dense...
Tom
Tom
