txaviator
There are three (3) rod end bearings on the rudder. I believe the part numbers are 3614 and 3616. The plans don't really specify which is which. Based on the quantity that Vans sent me, I am guessing the two SMALLER rod end bearings go at the upper and middle locations, and the larger one is on the very bottom? Can someone please help me out? The smaller ones are gold in color, and appear to be the same ones used on the elevators. I only have one of the larger rod end bearings, and it is silver. Is the silver one for the bottom location on the rudder? Thanks!
