tonyjohnson
The main gear mounts for the 8A require that you open an existing hole to 5/16 for the bolt that holds passes through the mount and the gear leg to hold the gear leg in the mount.
The hole on the other side of the mount is already the correct size. During a conversation I had with Vans it was mentioned that you REAM the undersize hole to 5/16. To do that I will have to find a 5/16 reamer, probably have to order it etc. I could just drill the hole out with a hand drill and 5/16 bit.
I am wondering what others have done in this situation. For those that drilled, have you experienced any problems?
