Just got a quart from SkyGeek. Royco 782 MIL-PRF-83282 for $8.99. Got some grease as well. Looking at the invoice and total shipping and handling was $10.31 which sounds a little high but not out of line. Maybe that was $4.00 shipping and $6.31 Hazmat but I'll never know
Bill S
7a almost there
...and you need to be very, very careful to not get any on your skin, at all!
My buddy had to re-route his brake lines in the cockpit of his-4 and got all sorts of scratches from sharp zip-tie ends. He then got this stuff on his arms and ended up in the emergency room, with severe swelling and contaminated blood!
Be careful,
Can some of the smart folks here make a suggestion?
Vans suggest you follow the manufacturers recommendation and states NOT to use Auto brake fluid. Mil spec 83282 is listed. Its not easily available but I can get it if its required.
On the archives, folks claim that MOBIL 1 Synthetic, without any silicone is great stuff and ideal.
So, comments welcome. ???![]()
Why hasn't anyone even mentioned 5606?
Hmm....Royco 782 (MIL83282) and Mobil 1 ATF are not "the same", at least per the data sheets I pulled up. Mobil 1 is a higher viscosity fluid with a lower flash point. Viscosity probably isn't a big deal at the altitudes we fly, but the whole point of replacing 5606 was to get more fire protection.
