Z Zazoos Well Known Member Mar 8, 2021 #1 The AC 8050-1 is new this month and has at least 3 new boxes. 13, 14, and 15. Not sure if boxes 13, 14 and 15 should be left blank or not. My EAA Step by Step Guide isn't as up to date as this form. Thank you for the help.
RV6_flyer Well Known Member Benefactor Mar 8, 2021 #2 Zazoos said: The AC 8050-1 is new this month and has at least 3 new boxes. 13, 14, and 15. Not sure if boxes 13, 14 and 15 should be left blank or not. My EAA Step by Step Guide isn't as up to date as this form. Thank you for the help. Click to expand... I retired from being a DARF 8-years ago so a current DAR may have more recent info. Just looked up the new 8050-1. (03/21 version) Box 13, 14, and 15 should have the same info as Box 1, 2, and 3. It is just a header on the continuation sheet 2. IF the two sheets get separated, it helps matching up the page 1 it belongs to.
Z Zazoos Well Known Member Mar 8, 2021 #3 Thank you for the quick response. VAF members are the best.
