Scarbrough
Member
I have a DeWalt 8" Bench Grinder and was wondering if anyone has ever mounted a 6" Scotch Brite Wheel to an 8" Grinder. Mine has the 5/8 Hole and I cannot seem to find them anywhere. Any help or advice would be appreciated.
They make bushings/adapters to fit the shafts for standard bench grinders.
What I ended up using for deburring was one fine 6" wheel and and one medium 6" wheel mounted to a Harbor Freight buffer on a stand.
Buffer:
https://www.harborfreight.com/6-in-buffer-61557.html?_br_psugg_q=bench+buffer
stand: https://www.harborfreight.com/universal-bench-grinder-stand-3184.html)
Advantages include easy access to wheel with longer shafts on each side. The medium wheel removes material quickly - very nice when you fabricate a part a little big and need to remove material to get it to size.
Parts like this I always cut with extra material and use the wheels to shape to size and deburr:
I got the HF idea from Synergy Air's class where they had it set up in their shop.
Long answer to a simple question but of all the tools in my shop this one got used the most and saved me a lot of time and aggravation.
The wheels used are Scotchbrite? The fine and medium wheels?
