LettersFromFlyoverCountry
The only drawing I can find in the plans regarding wing bolts is for a 7, not an "A" model. Obviously on the taildragger, having all bolts oriented from front to back is certainly not a problem. But with the gear weldments, some of the bottom bolts must be oriented back to front, right?
Also, I'm torquing the rear spar attach bolt and looking up the proper torque to use. Is this bolt a fine thread or course thread bolt and how does one distinguish the two?
