Chad: I have been flying this airplane for 31/2 Yrs. 550 Hrs. Just need something to do to keep from going crazy, or more crazy.cjensen said:How far along are you Doyle?
casper said:I would like to convert my 7A to a 7. Comments and tips welcomed. Looking for information on this endeavor. looking for motor mount trade or buy out right if you have the correct mount.
David, I think you are right, the about the aft bulkhead. I wish it wasn't so. If you still have that tail wheel set up I would buy it.David-aviator said:Doyle,
I had the mount and legs but these parts are long gone except I may have the tail wheel yet. Let me look around in the left over parts department and if I have it you can have it cheap. My RV-4 friend may have acquired it in the middle of the night. No, he wouldn' do that....
The change is not a big deal except getting the tail wheel hardware installed in the aft fuselage. I'd have to look at the plan, but it seems to me the aft bulkhead will have to come out to get it in and then reinstalled. There is quite a bit of stuff riveted to it. Maybe the bracket would go down and in from the top with HS removed, that part will be fun.
I don't think you will go crazy or bored flying the tail dragger.
casper said:David, I think you are right, the about the aft bulkhead. I wish it wasn't so. If you still have that tail wheel set up I would buy it.
David-aviator said:Doyle, I found it. Check your e-mail.
David, My E-Mail address is [email protected] What is your phone # I will call youDavid-aviator said:The message bounced. Your address must be dead.
Norman CYYJ said:Mounting the TD gear aft before hand will add too much weight in the tail and your CG will be too far aft.
BJohnson said:but not the tail wheel tapered steel spring, and leave it there for later?
