I'm following Checkoway's technique of using the ANL limiter, and running 8AWG wire for the main bus off the post on the limiter mount:
I need to get the correct size ring terminal... the post is about 5/16". All the ones I have from my Stein Master kit are too small. I can't seem to find the right one on Spruce (their ring terminals are all advertised for AWG10 and higher wire).
Any pointers to terminals that would work?
