G Gandalf Well Known Member Nov 4, 2016 #1 Can anyone confirm that the spacer holding the ignition box is position above the mounting point? If I put the spacer below the mounting point, the nut contacts a wire. Thanks
A Azjulian Well Known Member Nov 5, 2016 #2 I can confirm that's the way it is on mine as well - same as your picture
J JBPILOT Well Known Member Nov 5, 2016 #3 and I can confirm - - you DON'T want to leave it out ! Don't ask !
G Gandalf Well Known Member Nov 5, 2016 #4 Azjulian said: I can confirm that's the way it is on mine as well - same as your picture Click to expand... Thanks for the confirmation!
