Stockmanreef
I am wiring up the starter. At least getting the wiring there. I connected the WH-K910 wire to the starter relay and this wire is supposed to connect to the starter. The issues is that the ring terminal will not fit over the stud on the starter. The ring terminals appear to be the same on both ends. They are both red.
Am I supposed to drill out the ring terminal to a larger size? Should I clip off the current terminal and put on the correct one?
Why is the correct sized ring terminal not on the wire? I would assume that all the starters will be the same on the IO390.
Am I missing something?
Ken
Ken
