P PropMan Well Known Member Oct 29, 2019 #1 Anyone here recently purchased a 4 wing kit? I'm wanting to know if the spar is built or needs assembly?Thanks
M MS1095 Well Known Member Oct 29, 2019 #2 You have the option of building the spar or paying for the pre-built spar from phlogiston.
P PropMan Well Known Member Oct 29, 2019 #3 MS1095 said: You have the option of building the spar or paying for the pre-built spar from phlogiston. Click to expand... Thanks for pointing that out, just saw the option on the order form. I do plan on doing the assembly myself, to hopefully build light as possible. and do the 7.5" shortning as in the HR2 wing,with the larger tanks
