jbDC9
So I recently hit the 200 hr mark on my QB RV-8 and thought I'd share my experiences with the 4 into 1 exhaust system installed, just in case anyone else is considering such a system...
The original reason I went with this system was noise; the usual Vetterman type exhaust is just too loud for me and has a sharp, barking kinda quality to it. I called up Aircraft Exhaust Technologies (since merged with AWI) and asked about their crossover system with mufflers. Chris steered me towards the 4 to 1 system instead, saying it performs like a Powerflow tuned pipe, flows lotsa air, and the sharp exhaust note is mellowed out from blending the 4 separate stacks into one collector pipe. "Great!" says I, ship it!
I have no gripes at all about the pipes themselves; they're good quality, very well made and are holding up fine so far. My main beef is how the system interacts with the RV-8 airframe. I suppose that from the outside the noise is mellowed out, but from inside it was pretty noisy and buzzy with quite a bit of vibration through the floor... but since I've never flown in another -8, I had no basis for comparison on the noise/vibration level; I figured that it was normal -8 behavior. The noise/buzziness was worse at high AOAs and low airspeed. Also, in the pattern on base and final with the power pulled back there was quite a bit of popping and backfiring from the stack.
My first hint of trouble from the noise/vibration came at the 140 hour mark with cracks appearing in the forward belly skin between the gear legs; ref my previous post here - http://www.vansairforce.com/community/showthread.php?t=18402. I patched the cracks and figured that'd be the end of it. But alas, it wasn't to be. A few weeks ago (200 hrs) I was under the belly again wiping it down and I found a two more cracks just forward of the original ones. Well now, that does it; this pipe has gotta go! But first, I called AWI to see what could be done; it was suggested to try a down turned pipe tip. I had it within a week and had a local muffler shop weld it on. The end result? Holy-freakin'-moly, it's like a whole different airplane. It's much quieter and smoother than before, even with high power and AOA with low speed; methinks this will end the vibration and skin cracking problems. And, as an added bonus, the popping and backfiring at low power settings appears to have been eliminated; after 5 or 6 trips around the patch I didn't hear one pop or fart from the stack. Yea! I wish I'd known about such a simple fix 180 hours ago.
I don't know if any other RVs with 4 into 1 systems have had similar problems, but in my case it's been a real pain in the neck. If you're considering this exhaust or are already running one and if the noise/vibration seem excessive, put on a down turned tip before the skin cracks get started.
