birddog486
I need a measurement of the thickness of the ring gear assy. where it bolts to the crankshaft flange. IOW: how thick is the flywheel?
That's great thanks, I probably should have asked how thick the prop flange is on the crank itself also.
my crank flange thickness measured .439" on the YIO-360M1B.
