tadpole rider
Active Member
Am I correct in assuming that the WH-0046 wiring harness goes over the rudder peddle assembly like the three antenna cables? The instructions specifically instructed the antenna cables to go there but it is silent on the wiring harness.
Yup, over the rudder peddle assembly like the antenna cables. WH-00045, later, does as well.
Thanks for the quick reply.
The VAF is a really great resource. I've had a number of times where I had to wait for an answer to a question I had before proceeding and really appreciated the really rapid responses I got. You'll be able help someone else in the future.
