JDA_BTR
I have a question about locating the #27 and #30 plastibit needed to work on the wing lens page 17-09. I also looked at the change to the section 25 plans and need to find a 0.311 reamer (I have the 3/8 already).
The #27 is found at Avery, but the #30 plastibit (plexibit) I can't locate….
Will I need the whole Avery kit of bits, or should I just by the #27 for now?
Can the 1/8 plexibit suffice for a #30 match drill followed by a #27 final drill?
Avery has the .311 reamer…. maybe (says check to see if in stock)
