Kevin,
I have one based on the drawings in the Wing Plans that I can send you, it is in Power Point. Send me a private message with your email and I will send it to you. I don't know how to post it here otherwise I would.
Interestingly, the drawings in the wing plans use two different scales depending on the view. But if you compare the wing span and length measurements it can be corrected for. Van's latest newsletter gives the current measurements for the 12.
Your trailer concepts are great. One point in the previous thread was what could be used for a forward hard point. I think the steps would fill this quite nicely. Also, could the wings be stored under the aircraft, thus reducing the enclosure's width?
Regards, Dave
I just sent an email, Dave.
Not sure if the wings could be stored underneath. Are you talking about between the main gear wheels? That would depend on the wing chord. Or in a drawer or slot below the "deck"?
