dougknight
I have a lyc O-320-D2A that was converted from an O-320-E2D by a reputable engine builder with 370 hrs TT on it.
160 hp w/ 8.5:1 compression ratio
carburated
Slick mags 4370 (right-0 lag) and 4371 (left-impulse-20*lag)
RV-9A
Sensenitch WOOD prop
PC-680 battery showing 12.5-13.4 volts
Data plate on the engine and the lycoming manual both say 25* BTDC for the advance timing of magnetos to crank, which it is. However I just broke my second skytec flyweight starter due to kickbacks and I'm thinking it is because the lag on the impulse magneto is only retardeing at 20* allowing it to fire at 5* BTDC on start-up.
My question is if I change this timing from 25* to 20* what if any are the adverse effects. Loss of HP? if so how much. Am I increasing my chances of detonation? Increase/decrease CHT/EGT?
If I were to change left mag to 20* should I also change the right mag to 20* or leave it at 25* BTDC.
I would love to change the left mag (4371) out for a 4373 which has the 25* lag built in but I just don't have the money for that right now and think this timing change would keep from breaking starters untill I can afford the swap out.
Any advise from the engine guru's?
thanks in advance
doug
carburated
RV-9A
thanks in advance
doug
