Accessory Case driven Hall Effect Module systems:
Remove the Hall Effect Sensor Module cover plate and inspect for oil leakage and bearing wear. There should be no radial play of the shaft when moving the rotor.
I have crank triggers and the mag hole unit but I think two crank triggers are probably more reliable and fairly maintenance-free when set up correctly
