macrafic
In cases where I need to feed multiple components from a single source (avionics master switch, for instance), I will either use a terminal block or a fuse block, depending on the number of components, and the amount of current drawn in total and individually by the components.
However, when I only want to combine 2 or 3 wires into one, and the components are very low power (think LED lights), it seems such a waste to find a place for another terminal/fuse block and deal with that. There must be a way to combine the wires. I looked through AC 43.13, but could not find anything (I have to believe it is in there and I missed it. Everything else has been there in the past!!! Also looked on Aeroelectric, but could not find the answer there either.
Acknowledging that my "search" machine (me) must be having an off day, can one of you electronic gurus provide me some direction here?
