lostpilot28
I posted a message about pushrod length about 7 years ago before my airplane ever ran. Back then, I had two cylinders that had intake valve lash clearance that was at the very upper end of the spec (they both measured at .080"). Here's my post.
Anyway, I'm doing my annual condition inspection and these same two cylinders are now a bit out of spec. One has a .09" gap, and the other is at .1". The engine appears to run just fine, but obviously the gap needs to be closed up a bit. A 3rd cylinder is at .08 exactly. All of these are on the Intake side. The one remaining intake and the 4 exhaust gaps are all within spec around .07".
My question is, would going up to the next length of pushrod be enough? I've heard that the AEL73435 is .03" longer than my current AEL73434. I'm not sure if the rocker gives an exact 1:1 ratio, so I just want to make sure that up-sizing by .03" would be enough.
Last question is on the .08" gap...should I swap that one, too? Or leave it alone because it's technically "in spec"?
Thanks in advance...any help is greatly appreciated!
