Can you guys give me some feedback on this wiring diagram I just finished?
Here are my concerns:
1. Ray Allen diagram shows a 1A Circuit Breaker when using a rocker switch, however since I am using a Trim Relay Deck both Aileron and Elevator are powered off the same 1A power input. Is that going to cause an overload (I cannot find load information for those trim motors)
2. I am not using a Breaker and I do not have a disconnect switch (I already cut the panel too so I have no where to put it). Is this a problem?
3. Did I use the correct method of allowing both co-pilot and pilot to control the trim (simple splice)?
Any feedback would be appreciated. Especially if it addresses the concerns mentioned above. Thanks.
