Old 05-20-2013, 07:52 PM
tkatc's Avatar
tkatc tkatc is offline
Default Countersinking help
Maybe I should already know this but I'm a bit tired and need help.
I am machine countersinking the lower longerons to accept the skin dimples. #30 holes use a #30 countersink. Easy enough. But now I have to countersink for an AN509-8R8 screw. The hole is I'm guessing a 12 or 19 so my #30 countersink won't work very well in the larger hole even though all my countersinks are 100 degrees.
Please help my tired brain...
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
Old 05-20-2013, 08:46 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
http://www.cleavelandtool.com/Counte.../#.UZrf9coym2U
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-20-2013, 08:57 PM
Caummisar's Avatar
Caummisar Caummisar is online now
Default Use #8 CS screw
You need a #8 countersink.
http://www.cleavelandtool.com/Counte.../#.UZriXKKG2So
VAF# 835
RV-7A- Instrument Panel/FWF/Engine Mounted
Slow build --- ALL THE WAY
Victim of SB-632-B
2020 Dues Paid
Old 05-20-2013, 09:02 PM
clevtool's Avatar
clevtool clevtool is offline
Thanks for the links guys! The cutter will actually have a #19 printed on the side as the pilot size is a #19 wire size. This is the clearance hole size for a number eight screw.
Mike Lauritsen
Cleaveland Aircraft Tool
800-368-1822
www.CleavelandTool.com
mike.toolman (at) gmail.com
Like on Facebook - Follow on Twitter - See on YouTube
Old 05-20-2013, 09:27 PM
tkatc's Avatar
Hmmm. I got a #20... Close enough?
Track my RV7A!!
Old 05-21-2013, 11:32 AM
krw5927 krw5927 is offline
If you drill the hole at #20, and then use the #20 piloted countersink to the proper depth for the screw, you can then drill/ream the hole to #19 if needed.
Just drill the first hole to the same size as your countersink pilot.
Kurt W.
RV9A
FLYING!!!
