I have a Sioux 3X rivet gun I bought new a few years ago from one of the regular vendors who advertise on here. Ever since new ? the trigger does sometime stick , at a very fine teasing setting. This happen particular if you try and feather the trigger very carefully. When I got the gun I thought it would bed in once used, plenty of lubricant and a usage. Unfortunately it has not got better. It?s as it was when new . I only use it with -4 rivets. Works great. Just have to be careful when the trigger sticks ? gets tricky to remove the gun from what you are riveting.
Have anyone on here experienced something similar ? I am looking for a maintenance manual or parts list for the unit- Thinking about stripping it down to see if I can figure out what is causing the trigger to stick. Appreciate any advice.
The model number 270A
