Old 08-12-2006, 11:45 AM
prkaye prkaye is offline
Default primer bleed-through
I've been working on Van's practice project. Although there's obviously no need to prime the practice project, I am doing it anyway, just to get a feel for the entire process.
I laid the pieces down, backside up, and sprayed the self-etching primer onto the surface. The problem I had was that the primer leaked through to the other side (around the edges and through the drilled holes). What's the easiest way to avoid this? Put masking tape along the edges and holes on the non-primed side of the parts?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 08-12-2006, 12:28 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
You might be applying too much primer. Try a light "pink coat", allow to tack up, followed by a medium coat or two, allowing drying time between coats.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 08-12-2006, 12:52 PM
jcoloccia jcoloccia is offline
Honestly, I wouldn't worry about it too much. The first thing the painter's going to do when he gets your airplane is to rough the whole thing up. That will get rid of any primer overspray.
If you insist on worrying about it (), you can always just wipe off the overspray with some solvent. Even AKZO will come off for a good long time until it's actually fully set but more than dry enough to handle.
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
Old 08-12-2006, 04:23 PM
cytoxin's Avatar
cytoxin cytoxin is offline
Default too much
you are to close or too slow. get a handle on it now or it will just aggravate you as you go..spray can primers seem to flow a bit. the spray gun method works better. however you can overcome this simple problem with tecnique. 8-10 inces away sweeping from left to right in a parrallel stroke. you shouldnt have any rolling around corners. good luck
William Weesner/ still kicking.
Old 08-12-2006, 04:42 PM
Adam Adam is offline
Wink Less is more!
With primers "less is more" you don't want heavy coats of primer two light coats are all you need.
Adam Silverstein
Finnish 8-Soon!
Old 08-14-2006, 08:28 AM
mike newall's Avatar
mike newall mike newall is offline
While on this, a quick mention of the dreaded Sharpie bleed !
Make sure you remove all traces prior to painting as it seems to be able to bleed through most things - I had a slight bleed through to topcoat on one of the first test pieces
