Old 05-17-2013, 11:09 PM
fabricflyer fabricflyer is offline
Default Transducer Manifold question
When using a fuel injected engine and glass panel, what would go into the third hole of the transducer manifold (VA168), and what fitting is going to be required?
Old 05-18-2013, 08:18 AM
crabandy crabandy is offline
Oil press
Man Press
Fuel Press
Old 05-18-2013, 08:24 AM
AltonD's Avatar
AltonD AltonD is offline
Plugs. Not used on my machine. The manifold press transducer is mounted on the firewall, cockpit side.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 05-18-2013, 05:34 PM
Airhead Airhead is offline
Nothing for Dynon EMS. The mp transducer is supplied by Dynon and mounted on fw.
Bob B
RV-7A QB slider - IO 360 M1B Hartzell C/S prop w/Dual 10" Dynon Skyviews - Classic Aero interior. Florida (SFB) based. 170 hrs TT .
Old 05-18-2013, 05:58 PM
airguy's Avatar
airguy airguy is offline
The manifold pressure might have a connection for electronic ignition manifold pressure sensor if you have EI installed (I do).
Old 05-18-2013, 06:07 PM
rzbill's Avatar
rzbill rzbill is offline
I think most everybody runs the oil pressure per Vans plans. So..thats one connection.
If you follow Vans plans for the fuel pressure sensor mounting..... that is two.
The other is usually blank as has already been said.
Since manifold pressure is usually tapped from Cyl #3, use of the sensor manufold is not an advantage.
If you have a fuel flow meter, its mounting can (but does not have to) change where you decide to put the fuel pressure sensor.
Buying stuff from Oregon is not the only way. Plan YOUR system and purchase or make what you need.
I made a 2 port manifold and then used only one port.
If I had thought further into the construction future, I probably would not have used a manifold at all.
See HERE
Bill Pendergrass
ME/AE '82
Old 05-19-2013, 06:14 AM
Capflyer's Avatar
Capflyer Capflyer is offline
I cut the third port off. I'm toying with using it to join up the manifold pressure and tie-in to the 2 P-Mags mounting it on the right side of the firewall with the third opening connected through the firewall for MP to the GRT MP sensor instead of using a bulkhead T-fitting. If you do not have a use for the third port, cut it off and store it in the future parts bin. It just takes up space on the firewall.
https://www.dropbox.com/s/0625mojb2u...11.jpg?v=0mcns
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
