  #11
Old 05-17-2013, 12:24 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Originally Posted by chazking View Post
All, I'm applying my n-number (N1XS) shortly. Many of you know the regs well and wondered if I could use the following:?
http://tinypic.com/view.php?pic=2yo4vnc&s=5
I got gigged on my inspection because the N-number decal, purchased from Aircraft Spruce specifically for this purpose, had the 'B' character 1/8" too narrow. Yes, the DAR pulled out a scale and measured.
I don't think the design is a good idea - even if you get it past the DAR, a later ramp check or similar might end in tears.
*ETA - I really appreciated the orientation to detail that he provided. If you're in the MN area, you'd do well to look up Tim Mahoney when it's time for your inspection.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 05-17-2013, 12:29 PM
mculver's Avatar
mculver mculver is offline
You could make some legal 2" numbers, with these being additional "artwork". But I personally believe that doing it once, per regs, is the right answer.
-- Mike Culver;
RV-9 project sold but details of the build at
www.mculver.com
Old 05-17-2013, 12:57 PM
rvbuilder2002's Avatar
In a lot of different font styles (maybe all), it is very common for the letters of the alphabet to not all be the same hight.
Adjustments are made to some of the letters so that to our eye they all look the same size. Apparently, the large variation in shapes will trick out eye to thinking they are not the same hight, when they really are. This needs to be considered when ordering lettering.
Scott McDaniels
Hubbard, Oregon
Old 05-17-2013, 01:04 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Exactly, which is why you need a geometric font and not one that is visually corrected...
http://www.vansairforce.com/communit...8&postcount=10
I challenge anyone to find another standard font that meets (exactly) the FAA letter width and stroke width requirements as the correct fraction of letter height.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-17-2013, 01:16 PM
ChiefPilot's Avatar
This was ACS' N-number strip - not individually ordered characters.
But your point is well taken. Even ordering N-number decals from a well known supplier isn't a guarantee of accuracy.
Old 05-17-2013, 01:21 PM
vic syracuse vic syracuse is offline
Super Moderator
I am not aware of any legal 2" numbers. They need to be at least 3".
http://www.flightsimaviation.com/dat...art_45-29.html
VIc
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 05-17-2013, 02:15 PM
AX-O's Avatar
AX-O AX-O is offline
Default Question about ?NX? on N Number.
I am building an RV-4 and have been thinking about using the ?NX? on my N number to specify experimental. My question is this
When I use the N number during radio calls, do I say
November-one-two-three-alpha-bravo
Or
November-Xray-one-two-three-alpha-bravo
Or
Experimental November-one-two-three-alpha-bravo
Thanks for any help.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 05-17-2013, 02:21 PM
Mel's Avatar
Mel Mel is offline
2" numbers may be used on the RV-3 and -4 per 45.22(b), but not the RV-10, as in this case.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-17-2013, 02:23 PM
Mel's Avatar
Mel Mel is offline
When using the "NX" number on the aircraft, the "X" only replaces the 2" "experimental" placard.
The "X" does not show up in ANY paperwork, or within ANY radio communications.
Old 05-17-2013, 02:35 PM
AX-O's Avatar
Thank you Sir.
Axel
