Old 05-17-2013, 08:40 AM
SMRacer SMRacer is offline
Default Leading edge light replacement
My RV-4 has the Van's leading edge taxi light. Does anyone know if any of the AeroLEDs are a "drop in" replacement for the Van's light? I'd like to find a LED that I can substitute that requires no more than minor modifications.
Jim
N444JT
Leesburg, VA
Old 05-17-2013, 09:44 AM
Rupester Rupester is offline
Assuming you have the Duckworks mounting, you can fit a 6-LED Aerosun in there, but you'll want a spacer to move the Aerosun forward an inch or two. Otherwise it sits quite a ways back from the lens.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
