Old 05-16-2013, 09:27 AM
William William is offline
Default Transponder connector orientation from diagram question
Hello all today I'm wiring up my King KT-78A transponder to the AK350 encoder. My question is I have the wiring diagram but I'm not 100% sure how to deciphur the orientation of the connector with regards to the rear of the transponder and rear of the encoder. From the attached diagram am I looking at the wire side or the metal connector side of the harness?
thanks
Bill
RV6A flying as of November 8, 2016. N717WK
Finishing a RV10
Old 05-16-2013, 09:31 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Looks to be the side the wires go into.
Get a magnifying glass, and look at the back of the connector, you should see the identifying numbers and letters for the pins.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-16-2013, 09:34 AM
Hi Mike thanks for the instantaneous response time . Unfortunately I don't have the factory connector, I'm having to purchase my own from digikey.
Bill
Finishing a RV10
Old 05-16-2013, 09:36 AM
Mike S's Avatar
Senior Curmudgeon
Strictly a guess here, but I strongly suspect the Digikey unit will be marked the same.
Give Stein a call if he doesnt jump in on this thread.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 05-16-2013, 09:38 AM
Will do Mike, thanks for the advice.
Bill
Finishing a RV10
Old 05-16-2013, 10:18 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
The Installation Manual
http://www.neboservice.ru/docs/0897493001195543990.pdf
says that the view you show is the "front side" of the connector, so it's the side the circuit board plugs into.
Look at the edge connector on the ciruit board, often pin 1 has some sort of identifying reference mark etched into the copper traces.
If not, the fact that pins 1 and A at one end of the connector are ground might help identify that orientation by the amount of copper on the circuit board.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-16-2013, 10:52 AM
Hello Gil thanks for the response. I checked the circuit board and didn't see any indicators. The transponder I'm wiring is the KT-78a. The manual you posted was for the KT-78C. Are they wired the same way?
thanks,
Bill
Finishing a RV10
Old 05-16-2013, 12:10 PM
SteinAir SteinAir is offline
ON the unit itself, "1" is on the upper left, and "A" is on the lower left (similar to the KT-76A/C). If you drop me an email offline I can send you the correct manual for the 78.
Stein
Old 05-16-2013, 12:22 PM
Stein
Thanks Stein, email sent.
best regards,
Bill
Finishing a RV10
Old 05-16-2013, 03:28 PM
az_gila's Avatar
Smile
Stein
That says the the connector view (the pic you posted) is looking at the front side of the connector as stated in the manual...
Gil Alexander
