05-14-2013, 04:37 PM
What is the proper way to sign off the Annual Condition Inspection?
I received the message below from RARA today and I need to get it fixed.
I am working it but in the mean time if anyone has some precise wording they want to see, I would appreciate your feedback.
Not a lot of time left to fix this and I would like to take care of it in the first try.
Bob Axsom
Hi Bob,
The FAA was here the other day and they need you to fix the way your
condition sign off is signed. They said to sign it according to your
operating limitations and then send it back in.
Everything else looks good.
Dana
05-14-2013, 05:00 PM
Wording for signing off condition inspection is in your operating limitations, paragraph (23).
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
05-14-2013, 05:03 PM
I certify this aircraft has been inspected in accordance with the scope and detail of CFR part 43 appendix D and found to be in a condition for safe operation.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
05-14-2013, 05:06 PM
Out of 8130-2G: "I certify that this aircraft has been inspected on (insert date) in accordance with the scope and detail of appendix D to part 43, and was found to be in a condition for safe operation." Include the time in service, name, signature, certificate number, and type of certificate held by the person performing the inspection.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
05-14-2013, 07:22 PM
Thanks guys
Mine is stated in paragraph 10 but the words are as you say.
Bob Axsom
05-14-2013, 07:54 PM
What text would you put into the engine logbook?
Neal Howard
Airplaneless once again...
05-14-2013, 08:35 PM
Bob Axsom
For several years, some DARs were "renumbering" paragraphs when leaving out the ones that don't apply to certain aircraft.
The "renumbering" was discovered about 5 or so years ago and since then all paragraphs numbers should match the ones published in 8130.2G.
05-15-2013, 06:15 AM
The same wording, just change "aircraft" to "engine".
05-15-2013, 05:12 PM
Reworded log entry accepted
Got word late last night that the new wording was accepted. Next is the PRS experience and tests.
Bob Axsom
