Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 05-13-2013, 08:37 PM
Weasel's Avatar
Weasel Weasel is offline
Default GTN re-initiate hold
When you load an approach that has a published hold you are asked if you want to fly the hold. If you select NO, what is the procedure to re-initiate the hold?
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1600hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 05-13-2013, 10:14 PM
Gash's Avatar
Gash Gash is offline
ooooh, that's a good question. I don't think that's in the manual. I'd be curious to know the answer as well. Surely we don't have to reload the approach??
Karl, Goodyear, Arizona (KGYR) ATP, CFII
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
Bearhawk 4-Place, Sold
=VAF= donor 2020
Old 05-13-2013, 10:56 PM
I do not have a GTN series. On the 400 series, I don't know how to do this without re-entering the procedure IF you want the Garmin to guide you around the hold. If you are willing to hand fly the hold (or 'hand fly' your autopilot in heading mode) then set the OBS/HSI course to the holding leg course (inbound to the fix) and, prior to the holding fix, push the OBS button on the Garmin to suspend sequencing. Hand fly the hold entry and hold. When ready to proceed inbound, and just prior to the fix, push OBS on the Garmin and it will start sequencing again, providing course guidance for the approach.
Old 05-14-2013, 07:50 AM
Brantel's Avatar
Brantel Brantel is offline
Pretty sure the only way to get it back in there is to reload the approach. There is no way that I know of to add complex items (like holds, procedure turns, altitude legs, etc) individually to the flight plan manually.
What I do is go ahead and tell it to keep the hold and then either delete it from the flight plan when I am sure I won't be using it or just select the next leg after getting established on the next course.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 05-14-2013, 08:34 AM
Weasel's Avatar
Thanks. I will probably start doing it this way. Sortof a pain when given hold instructions after it is deleted. Garmin should consider updating the firmware to allow this and give us hold options at any fix not just published holds.
Weasel
RV-4 715hr Sold
RV-8 700+hrs
SERFI AWARDS
Old 05-14-2013, 09:52 AM
Brantel's Avatar
In some cases hands are tied by regulations and functional specs handed down by the FAA.
This may or may not be the case here I don't know...
Old 05-14-2013, 11:00 AM
Auburntsts's Avatar
With the G1000, I believe you can do it by making it a Direct-To waypoint and going into OBS mode which will stop auto squencing. Then when you're ready to resume you toggle out of OBS mode and fly the original approach and/or flight plan.
The 650 may allow you to do it the same way.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
