Best preflight
Same happens with military planes at air shows. Believe it or not, I have also seen pilots do it, usually they check six, think we are not looking then push buttons in the cockpit...especially if it is on the controls and says anything about ordnance!
Afterwards do the BEST preflight ever, I recommend a very thorough FOD inspection too. I have found all sorts of things you would never think of (worst is a used sucker stick).
As for the sign, if you want a few for other planes as well, and want to try your hand rolling your own, get a cheap sewing machine from a store near you. $99 or less with coupons. Buy naugahyde at a fabric store. Cut letters out of a contrasting color. Cut other color rectangle about 1-1.5" larger than 2x your prop's largest blade "circumference". Sew letters on bottom half, fold in half with fold on top, sew bottom and appropriate end. Make 2, 1 for each prop blade.
If you already have the sewing machine, this will be very cheap. I have done this for machine covers in the workshop, very easy to sew.
RV-? in planning stages.
RV-14 #140050 SOLD
Permanently willing to contribute fuel for RV rides
Helicopter ATP/CFI(I)
ASEL/AMEL Commercial/Inst/CFI(I)
Aerobatic Instruction available
Atlanta based.
