  #61
Old 03-14-2016, 06:54 PM
Berchmans Berchmans is online now
Default ELT Antenna Placement
Here are three photos of how I located my ELT Antenna under the canopy of my RV8.
I fabricated a small bracket that mounts between the members of the mid cabin cross bar.
The bracket is angled slightly as can be seen in this photo. While it does momentarily touch the front bow of the canopy as it's closed it does not contact the inside of the canopy at any point so there is no danger of scratching the surface.
The rear passenger when entering the aircraft does need to be careful not get hung up on it but that's the only drawback I see.
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2020
Old 03-14-2016, 10:49 PM
gladiator68 gladiator68 is offline
Default Can you post a pic
Hi Gary,
Your installation sounds like a good idea. Can you post a pic so we can see it?
Thanks for your real world feedback!
Rick Glatthaar
Olympia, WA
RV-9
Tail done, wings done,
Fuselage "almost" complete, working on wiring/panel
Sending $10 monthly in 2020.... Thanks Doug!!
Old 03-23-2016, 02:19 PM
BonitaRV8 BonitaRV8 is offline
I was going to mount mine similar to Burke's but maybe put the bracket in the center of the back of the pilot's seat. Any reason that's a bad idea other than the passenger having to negotiate around it getting in and out?
Empannagee done
Wings 90% done
Received fuselage
Old 04-07-2016, 06:58 PM
judoka5051 judoka5051 is offline
Default I used this...
I used this ELT mounted on the left side front seatback weldment plate. I gently formed a curve into the antenna to match the canopy. It points away from passengers when they enter the airplane, and I never had a poked eye! I will admit that I used this ELT primarily to save weight.
http://www.aircraftspruce.com/pages/...c/ebc_elt2.php
Lance Logan
McAlpin, FL
Plane at FL10
Scratchbuilt Biplane
Preceptor N3 - Sold
Zenith Zodiac 601HD - Sold (good riddance)
Kitfox IV - Sold my share, but loved that plane
RV8A Sold! Loved the plane, but not the nosewheel!
RVX (RV6/4) Sold
Cherokee 180 pickup truck
RV8 Fastback
Old 04-07-2016, 09:06 PM
aerovin aerovin is offline
I know the aesthetics are not great but a small doubler plate and a simple installation that is out of the way and meets the ACK installation instructions meets my needs:
I've hardly thought about this antenna since installed and have had no issues with it at all.
Scott Thompson
RV-8 N9324Z (flying as of 8/30/15)
http://www.aerovintage.com/rv8/rv8-index.htm
Old 09-14-2016, 08:00 PM
skyking902001's Avatar
skyking902001 skyking902001 is offline
Default Antenna wiring
I was planning on putting the antenna under the empenage fairing. However, the new 406 antenna's are too long to mount on the aft bulkhead. So, now thinking about installing on the passenger armrest. My question is how to get the antenna coax from inside the cockpit back to the ELT unit without penetrating a bulkhead?
Steve Riffe
RV-8
N23SR
Dues paid to 12-1-20
www.mykitlog.com/skyking90200
